schreckman Posted September 12, 2003 Share Posted September 12, 2003 In theory this should not happen. I got this 92 Loyale Auto 4x4 and has a leaking front diff. It looks as if the fluid comes out of the dipstick hole after it is driven. I am thinking a side axle seal would make more sence. Anybody had a situation that has caused fluid come out of the dipstick hole? Quote Link to comment Share on other sites More sharing options...
Guest taprackready Posted September 12, 2003 Share Posted September 12, 2003 Your correct in thinking it shouldn't come out of the dipstick tube at any time. I wonder if you've checked the fluid level. I'm thinking its been overfilled. Bill Quote Link to comment Share on other sites More sharing options...
schreckman Posted September 12, 2003 Author Share Posted September 12, 2003 Yes, I just changed it because it did have ATF in it and that is why I thought it was comig out of the tube. I have it to the correct level with 90 weight. I think I will wash it off again and try to see how it starts. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted September 12, 2003 Share Posted September 12, 2003 Check your transmission fluid level. There is a seal between the front diff and the transmission, and when that seal goes bad, the fluids swap places, and the ATF can't lubricate the hypoid gears well enough and it will eat the front diff. So, if your tranny is way full, and smells like 90W gear oil, you have a bad seal, and it would be cheaper to replace that seal now, than replace the seal and the front diff later. Quote Link to comment Share on other sites More sharing options...
schreckman Posted September 26, 2003 Author Share Posted September 26, 2003 Hondasucks you hit it right on the money. I was driving back and forth to work and washing it off each time. I used my vacuum pump to extract the fluid down to the exact level. Everything was fine but then my auto tranny was low. So I filled that and then my diff was too full. Any Idea if I can pull the auto trans portion off of the diff and change the seal without removing the diff and axles? I have pulled several of the manual trans from these cars but no auto 4x4. Quote Link to comment Share on other sites More sharing options...
stephenw22 Posted September 27, 2003 Share Posted September 27, 2003 Some autos (turbo autos) have a removable front section for the diff. I'm not sure if your tranny would have that. Quote Link to comment Share on other sites More sharing options...
brus brother Posted October 5, 2003 Share Posted October 5, 2003 Seems like my tranny fluid and front diff fluids are mixing it up. Does anyone know on a 90 Loyale AT whether the tranny can be removed to repair the seal or do you have to come in the front way? Quote Link to comment Share on other sites More sharing options...
schreckman Posted October 5, 2003 Author Share Posted October 5, 2003 My understanding is there are several seals between the tranny and the diff and through to the tourque converter. I have parked une until after elk season when I will have more time. I am thinking I will just rebuild the whole thing while I have it out. Quote Link to comment Share on other sites More sharing options...
