July 7, 200520 yr i just bought an 84 Gl 4sp 4wheel hi/lo, i need some tips suggestions on how to make it insane and run strong. i also need some help location the manifold to run to carbs. let me know ...thanks jeff
July 8, 200520 yr Exhaust, take the cats out, straight pipe. check this for the dual carbs http://www.ultimatesubaru.org/forum/showthread.php?t=39045 what are you going to do with this car?
July 9, 200520 yr if you want it insane, put a huge lift on it and some super swamper boggers, then drop some engine in like a ej22. then, top is off with a fart can j/k
July 10, 200520 yr to go totaqlly in sane i reccomend replacing your origonial morot with an er33 and super charging it. serously don't to add power i would do an engine swap to an ej82t but that would require some funding and technical know how and the proper tools other wise a complete tune up and new fuel filters would be a good start if you keep your current engine
