VW to Subaru part interchange
Just found out that the VW bug, rubber steering copular, is nearly identical to the Gen 1 cars! You know the rubber disk near the steering u-joint.
(Thanks Rattle wagon)
I installed it on by GF with 230K on it and what a difference! The steering is tight and very responsive. I had already replaced ball joints, inner and outer tierods, but this really tightened up the steering. Cost....$8
(Be sure to use your original 4 steel sleeves. The VW ones are a bit to big.)
Other VW parts.
Gen 1 staton wagon rear glass = VW beetle rear glass
Windshield washer sprayer = VW beetle washer sprayer
GF side glass seal. (seal between front and rear window) = VW beetle convertible side glass seal.
Does anyone know other interchanges??
Todd
good info, thanks. dp
Other VW parts.
Todd
I have one on all my cars it really improves road feel , but sometimes your steering joint becomes loose you can tighten it by squeezing the bearing cups tight and re-staking them either that goes or the lower steering column bushing and washers wear out.
yeah and the cool urethane couplers can be used then hehe
I am wondering if the quick ratio coupler will work then hmmmmm hehe
oh yeah and also I should pull out my datsun restoration catalog and go though it again for some of the cooler stuff (after looking at the door weatherstripping again I might be able to find that in there too YAY!!) cause I have found in there rebuild kits for the u-joint half shafts in it and side marker lights for the stage 1 vehicles among a ton of other things including performance pieces :grin: like in the way of urethane bushings and stuff hehe
yeah I will dig out their sites url for ya but it's mainly a Z car restoration company but alot of the stuff will transfer over with minimum fuss
Going further OT: Anything 510-ish in the restoration catalogs???
not a prob and yeah there is some 510 stuff that interchanges too including the side mirrors! heck I saw a F10 (way old datsun) before and had chrome or polished metal mirrors!
there is an f10 in a yard not fare from here hum might have to have a look at the mirrors to see if they would work on my wagon..... you know fender mirror s like the jap cars....
