yohy Posted July 22, 2005 Share Posted July 22, 2005 Can anyone advise if the cam cap does anything except cover a hole. In other words, does it support the cam in anyway? Or is replacing the o-ring as simple as removing two bolts, taking the cap off, replace the o-ring, then replace and torque the two bolts? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted July 22, 2005 Share Posted July 22, 2005 the cap does come off. slides out. if it doesn't want to come out, just twist it gently back and forth and it'll eventually come out. i believe the seal is retained in the cap as well. replace both the seal and the o-ring if it has both. Quote Link to comment Share on other sites More sharing options...
yohy Posted July 23, 2005 Author Share Posted July 23, 2005 Gary thanks for the reply. I was worried that the cap might support the camshaft end or perform some other function that could go terribly wrong when the cap was pulled off. So give it a twist if it doesn’t want to come right off? Thanks again. Quote Link to comment Share on other sites More sharing options...
pandaB Posted October 16, 2005 Share Posted October 16, 2005 Yohy- Have you replaced the o-ring for the cam cover yet? How did it go? I have a similar problem with the cam cover cap leaking. If you take the cover off will oil flow freely, thus requiring the o-ring replacement to be done at an a oil change intervval? How easy was it to replace the cam seal? Quote Link to comment Share on other sites More sharing options...
yohy Posted October 16, 2005 Author Share Posted October 16, 2005 Yohy- Have you replaced the o-ring for the cam cover yet? How did it go? I have a similar problem with the cam cover cap leaking. If you take the cover off will oil flow freely, thus requiring the o-ring replacement to be done at an a oil change intervval? How easy was it to replace the cam seal? pandaB, Gary was spot on, I had to twist the cover back and forth while pulling outward. I was just a bit, check that, a lot nervous about pulling that cap off. Just to easy your nerves, it came off and went on without a hitch. It doesn't have any tension on it like it is actively supporting the cam (so when you pull it off, things go twang and fly all over the place!). Oh, the torque specs on those bolts is 12 ft, lbs. and you will be replacing an o-ring on the cap. Again, I was nervous about pulling that cap, but it was a non event, no leaking oil, no parts flying around the garage. Go for it. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted October 17, 2005 Share Posted October 17, 2005 Just to clarify....there's no seal and o-ring. The o-ring is the seal. There are seals on the front however, only an o-ring on the rear.....and yeah it's a pretty simple task to replace the o-ring. Quote Link to comment Share on other sites More sharing options...
