EA82T fuel tank drain plug?
Does this car even have a drain plug? It's an '85 EA82 turbo wagon
Before I got the car, it sat for 6-8 years with 2/10 ticks of gas on the digi-gauge. When I first filled it up, I had to take out the fuel gauge sender and knock a LOT of rust off it to let it move & work. I also replaced the fuel pump with a junkyard one to get it running.
Since I replaced the pump, it has made a loud humming noise very noticeable inside the car.
Big problem right now... when the tank gets lower (not always though), if I hit the gas, it will hiccup, very badly at times. It's bad enough I don't let the wife drive it at all.
I just replaced the fuel pump with one out of an 87 wagon, and it hums very sporadically at the moment. I also took the fuel filter off and dumped the RUST COLORED gas out of it. I also ran the pump for a little while just emptying into a can, and it eventually turned to clear gas; although I fear there is still a lot of crud left in the tank.
Whew... long winded history for the following questions...
- Is there a drain plug on this tank? Just because I didn't see one doesn't mean it isn't there. Doing some searches I only found reference to EA81 drain plugs. I already found instructions to remove the tank, which I could do if I had to.
- Is it feasible to remove the tank, then add a drain plug?
I realize I could just keep changing the filter and not run the tank low, but that would treating the sympton, and not the cause :rolleyes: btw, this car is not by daily driver, so I can take my time working on it.
Thanks in advance,
-Dave
Yeah, my '74 Datsun Z had a drain plug, very handy when working on a car that has sat idle for a few years. Only down side I can see is it makes it pertty easy to steal somebodys gas, just a bucket and a wrench. I'm betting the factory dropped them to save the 29 cents on building each tank.
Gary
When you changed the fuel pump, did you get one from either a MPFI or turbo engine-equipped car? The pickup tube in the tank has a sock that probably needs replaced.
The first replacement fuel pump that got it running was from a turbo car. This pump is now humming/vibrating like crazy.
The pump I just put in it is from an SPFI wagon. This pump has hummed a couple times.
I've read the pumps are the same between SPFI/MPFI??
Also just remembered/realized that I'm going to eventually do a 5spd swap on this car, so the tank will be exposed and *easy* to remove and clean.
Qman, thanks for the confirmation that there isn't a drain plug.
