bella Posted August 5, 2005 Share Posted August 5, 2005 There will be a problem if instead my original tires(175/75/13) I put 185/85/13??? Thank you allot, all members. Quote Link to comment Share on other sites More sharing options...
Brumby Boy Posted August 5, 2005 Share Posted August 5, 2005 other than the spedo being out i dont foresee a problem Quote Link to comment Share on other sites More sharing options...
soobmater Posted August 5, 2005 Share Posted August 5, 2005 Yep, your speedo will be off about 5 miles per hour at 50. there shouldnt be any problems. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 5, 2005 Share Posted August 5, 2005 Do you want the extra circumference of the tread? If you just want a wider tire than the 175/75-13, have you considered 185/70-13, which should be approximately the same height/circumference as the 175/75-13. Quote Link to comment Share on other sites More sharing options...
bella Posted August 8, 2005 Author Share Posted August 8, 2005 Thank you. This tires I will buy.. A nice day. Do you want the extra circumference of the tread? If you just want a wider tire than the 175/75-13, have you considered 185/70-13, which should be approximately the same height/circumference as the 175/75-13. Quote Link to comment Share on other sites More sharing options...
FirstSubaruGLwagon Posted August 8, 2005 Share Posted August 8, 2005 just make sure you put them on all 4 wheels. important to keep the tire diamiters the same in order not to mess up the 4wd durring street use. Quote Link to comment Share on other sites More sharing options...
freedster Posted August 8, 2005 Share Posted August 8, 2005 Nice app here to give you the exact error: http://www.miata.net/garage/tirecalc.html HTH. - Freed Quote Link to comment Share on other sites More sharing options...
