froggymike Posted August 15, 2005 Share Posted August 15, 2005 ..on Murphy the 87 T-Wag not working. Where is the relay that makes that work. the wipers work but don't return to the resting position, and I assume this is also controled by the same relay. Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted August 15, 2005 Share Posted August 15, 2005 as a quick test, put another ground wire between the wiper motor and the body. That's all it took to fix the herky-jerky intermittant wipers on my car, and several other peoples cars IIRC. Quote Link to comment Share on other sites More sharing options...
NorthWet Posted August 15, 2005 Share Posted August 15, 2005 In general (non-soob specific) wiper return is controlled by the wiper gearbox/contact plate. As suggested, a better ground might help. Quote Link to comment Share on other sites More sharing options...
stephenw22 Posted August 15, 2005 Share Posted August 15, 2005 On my turbo wagon, the electrical contacts in the wiper gearbox were all bent out of shape. I took the cover off (3 screws, if I remember correctly) and straightened them with some needlenose pliers. They worked for another couple of years until I retired the car. Quote Link to comment Share on other sites More sharing options...
Ross Posted August 16, 2005 Share Posted August 16, 2005 The control relay can cause exactly that symptom, its a large ish can up above the drivers feet on ea81s, probably the same on ea82. Quote Link to comment Share on other sites More sharing options...
TahoeFerrari Posted August 16, 2005 Share Posted August 16, 2005 I second Ross's post - a bad intermittant wiper controller can cause the same symptom. On my '87 3-door it's located on the back of the kick panel above the driver's legs - just to the right of the fuse box. It's very easy to get to. I've yet to find it on my '89 (which has wiper problems). I think it is behind/above the ECU, but haven't had time to take things apart to find it. Quote Link to comment Share on other sites More sharing options...
