apexi super ground system
Does anyone have experience with the apexi super ground system? What are the benefits? Draw backs? How does it work?
Mike
I guess it must be magic! No one know about magic??
I'm not familiar with that exact kit - I assume it is a wiring kit?
many Subaru owners have reported issues caused by poor grounding of sensors, relays, etc, due either to bad contact through paint or corrosion in extreme environments. I suspect most of any improvement those kits yield could be had by just going through you car as is and 'freshening up' all the ground connections you find. Take 'em loose, inspect the wire and connector. wire brush them to bare metal, reconnect them, maybe cover with some grease or other 'barrier' compound. Of course, if you've added some electronics or beefier stereo gear, that comes with its own electrical demand issues. The wiring kits also add a 'bling' factor from what I've seen that may make it worthwhile for some folks. You could dig around over at http://www.nasioc.com More tuner/modder type folks over there.
Carl
