all the lights on the dash or just the ones on the instrument panel?
not to knowledgable with imprezas but on the switch for the hd/lights,i know on some cars i've owned there's a seperate switch for the dash lights.
(so you can light up the dash without putting the hd/lights or other outter lights on)
Went and looked... its the dash lights, the radio lights and the heater control lights.
Check on top of your steering wheel and see if the park light switch got bumped on. Did you clean on it today.
that should only turn on exterior parking lights.
that's just weird,cause normally all lights go off with ignition switch.Hmmm
well if your worried about the battery.you could always disconnect it.sorry i couldn't be of more help
Yep. ur right about the parking lights. Agreed about the lights going off when key is off.
Hmmm.
Whats the fuse for those lights? I cant find it in the manual.
Sounds like there may be either a short someplace back feeding the circuit, or the light controller or amplifier (it must have something like that) is bad. The little wires in the stalk cant carry all the current to control the lights, so it feeds some little black box, which actually control the lights.
Joe
