September 26, 200520 yr i have a 97 obw and when i go start it, it starts then it stutters and shuts off. what is the problem here!!!???
September 26, 200520 yr check for vacuume leaks, happens to me every once in a while, some of the big hoses, when they fall off the plastic intake tube will stall the motor real quick.
September 26, 200520 yr Did you fiddle with the air filter recently? If so, look under the air intake tube just past the MAF and make sure all the little hoses are still attatched. Ask me how I know. Ryan
September 26, 200520 yr Author Did you fiddle with the air filter recently? If so, look under the air intake tube just past the MAF and make sure all the little hoses are still attatched. Ask me how I know. Ryan WOW !!I did fiddle with the air filter riiight before this morning, post some info pleasE!! i already have a tow truck comin in tommorow 100$!!!
September 26, 200520 yr Ask me how I know. Probably the same way i know, oh man can that be frustrating if you gotta be somewhere soon and the car dosn't run.
September 26, 200520 yr Check the underside of the air cleaner assembly about halfway to the wheelwell, you should see a tube about 1.5 - 2 inches in diameter that needs to be reattached.
