September 28, 200520 yr hi guys, seldom post on this side of the board. but had a question... ho makes the best (easy accsess) to a 94 leg wiring diagram... i need one for a 94 sedan 4x4(ls) with abs. and SRS. anyway if there are no online places. which books do you recomend? chiltons hayens ect..... thanks
September 28, 200520 yr http://www.ultimatesubaru.org/forum/showthread.php?t=43489 dig through that thread, there are a couple of sources on it, dont know if that will help .. nipper
September 28, 200520 yr Generally, I think the Chilton's schematics are easier to use than the Haynes.
September 28, 200520 yr Author thanks, i downloaded th pdf's but will probalby pick up a chiltons. also.... i think i have what i need. thanks
