adwolf1 Posted September 29, 2005 Share Posted September 29, 2005 Winter is coming & i'm thinking about getting snows for the legacy. It's a 2003 L, runs on 205/55 x 16 stock. I was thinking of getting 195/60QR15 blizzak revos, mounted on some crappy 15x6.5 rims. Not being familiar with 'minus-sizing', would these look OK? is the total circumference different than the stock 16" wheels? (I can't tell if the higher sidewall makes up for the lower rim diameter.) Thanks! Quote Link to comment Share on other sites More sharing options...
nipper Posted September 30, 2005 Share Posted September 30, 2005 http://www.tirerack.com/tires/Spec.jsp?make=Bridgestone&model=Blizzak+WS-50&vehicleSearch=true&fromCompare1=yes&partnum=07R5BZWS50 Use the revolutions per mile to check the cricumfrence betwen the tires you have now and the blizzacks. The rotation per mile is found on the tire specs tab of any given tire. nipper Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 30, 2005 Share Posted September 30, 2005 My only worry about Minus sizing would be clearing the calipers, other than that you should have no troubles. Might throw off the speedo, but i'm sure you don't use it anyway. Quote Link to comment Share on other sites More sharing options...
