Ignition Switch / Steering Lock
I'm stripping an 87 DL down to the bone and would like to keep the keys/locks together as a set. Is the ignition switch/steering-column lock removeable? It seems to be on there pretty good.
The locking collar is not, but you can pull the key cylinder and switch out of it. They are separate pieces.
They are break away bolts on the starter switch when i had to replace mine. Bring a portable drill as they are easy to drill oout. Also a lock smith can put all the cylinders on one key for you very easily.
nipper
