Brian G Posted October 12, 2005 Share Posted October 12, 2005 I want to replace my 4EAT with a 5MT. Will the diffs that I used with the auto fit the manual? Thanks, gang. Brian G Link to comment Share on other sites More sharing options...
Snowman Posted October 12, 2005 Share Posted October 12, 2005 Maybe... Your differential most likely has a 3.7:1 ratio, and the 5MT has a 3.9:1 ratio if it's from an n/a. If it's from a turbo car, the transmission most likely has a 3.7:1 ratio, so you can use your differential. Link to comment Share on other sites More sharing options...
Brian G Posted October 12, 2005 Author Share Posted October 12, 2005 My diff's ratio is 4.44. I was wondering if I can remove the diff from the transmission and use my 4.44 instead. Brian G Maybe... Your differential most likely has a 3.7:1 ratio, and the 5MT has a 3.9:1 ratio if it's from an n/a. If it's from a turbo car, the transmission most likely has a 3.7:1 ratio, so you can use your differential. Link to comment Share on other sites More sharing options...
carfreak85 Posted October 12, 2005 Share Posted October 12, 2005 What kind of car do you have? Link to comment Share on other sites More sharing options...
Brian G Posted October 12, 2005 Author Share Posted October 12, 2005 The transmission and rear end that I have are from a '97 Outback Limited. The car they're going into is an '88 XT6 . I want to keep the 4.44 ratio but switch to a manual transmission, but I don't know if I can mate the front diff to a 5MT. Brian G Link to comment Share on other sites More sharing options...
