xoomer Posted October 18, 2005 Share Posted October 18, 2005 Any Ideas on the code? I can't find it in the FSM? -x Link to comment Share on other sites More sharing options...
zyewdall Posted October 18, 2005 Share Posted October 18, 2005 Any Ideas on the code? I can't find it in the FSM? -x I got an 11 and a 13 when my disty was out, but I never got a 12. I don't have my chilton's handy, but it did have a list of all the codes. Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 18, 2005 Share Posted October 18, 2005 assuming 88 or later MPFI, the USRM ECU guide says it's the 'Starter Switch or Circuit' good luck from there Link to comment Share on other sites More sharing options...
Ross Posted October 18, 2005 Share Posted October 18, 2005 Is this code there with the engine running? Link to comment Share on other sites More sharing options...
stephenw22 Posted October 18, 2005 Share Posted October 18, 2005 On my '85 that was the code you got when the engine was running. (letting you know that the car is ON) Link to comment Share on other sites More sharing options...
idosubaru Posted October 19, 2005 Share Posted October 19, 2005 for an 86 it is "Starter circuit OFF". Link to comment Share on other sites More sharing options...
Bobby_boucher Posted October 19, 2005 Share Posted October 19, 2005 It just means its running and starting isnt. Link to comment Share on other sites More sharing options...
xoomer Posted October 19, 2005 Author Share Posted October 19, 2005 ok when i drove it around the block I got a blinking ECU Light on the dash Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 19, 2005 Share Posted October 19, 2005 ok when i drove it around the block I got a blinking ECU Light on the dash if you have the green connectors connected, the CEL will be off for a little while, then blink if there are no codes. Just disconnect them and go on your way Link to comment Share on other sites More sharing options...
