October 18, 200520 yr Hi, i own a 93 legacy and im not to sure where the fuel filter is, is it the one near the brake fluid? and how do i check to see if its dirty. It has over 280k and running with the original fuel filter, think it need a change? O and i was also wondering how i get to the light under the shifter, its a automatic.
October 18, 200520 yr The fuel filter is the metal can with two hoses coming out of it on the driver's side between the brake fluid reservoir and the strut tower. I suggest replacing it. It's very simple to do. Matt
October 18, 200520 yr Author Thx, now how do i know if its durty? and does anyone know how to acess the light under the shifter on a automatic?
October 18, 200520 yr Well if you dont know the last time you changed the filter, you just change it . The light under the PRND21 you have to partially disassemble the console, which is not all that hard to do. I think you start with the two screws under the center arm rest then it comes apart like a jigsaw puzzle.... im not sure been a while since ive seen one from 93. nipper
