October 25, 200520 yr I have a 2000 Outback with approx. 130000 kms/60,000 miles and it seems to use oil.It doesn't smoke or seem to leak but I would say it uses maybe a litre of oil every 2000 to 3000 kms.Is this excessive for this vehicle.I know with North American vehicles the PCV valve can cause oil problems but I'm not that familiar with these.BTW it's a 2.4.
October 25, 200520 yr I have a 2000 Outback with approx. 130000 kms/60,000 miles and it seems to use oil.It doesn't smoke or seem to leak but I would say it uses maybe a litre of oil every 2000 to 3000 kms.Is this excessive for this vehicle.I know with North American vehicles the PCV valve can cause oil problems but I'm not that familiar with these.BTW it's a 2.4. I think that is 'disappointing' oil usage but maybe not indicative of any particular failure. I'm sure you car would have the PCV valve system and it may very well need servicing. You might consider a heavier weight oil - at least through the summer months and see if that helps. Examining all 4 spark plugs may be a good idea, in case one cylinder is exhibiting a problem. A better test might be compression/leak down but I would start with the PCV and maybe heavier (higher viscosity) oil.
October 25, 200520 yr That is not enough consumption to cause alarm. However, servicing your PCV system could reduce it.
