November 2, 200520 yr Any one here look into pillow ball upper strut mounts yet? (for the EA82) Would give us an eazy way to adjust camber, not to mention improved handeling:) I'm SURE ther is an app. that would work on our cars, just not sure how to find that out and where to get it:confused:
November 3, 200520 yr Hey I tell you what, take some measurements and send them to me. I believe that the CUSCO pillowball mounts I have on my Starlet Glanza V will work. They look really close. I mainly need the measurements between the 3 studs. The only thing that I could foresee is having to drill an extra hole for the 4th stud to go through. Let me know. Patrick
November 4, 200520 yr Author I'll take some today and post 'em! I can't beleve no one here has looked into this yet:-\ This would stifen up the front end, AND give us an eazy way to adjust camber.
November 11, 200520 yr I think that Legacy/Impreza camber plates will fit if you file out the three strut stud holes a bit.
November 11, 200520 yr Author My bad! I forgot to mesure:rolleyes: I will do it some time tomorow and post up.
November 11, 200520 yr wt2ya..... any impreza/legacy/forester/baja/sti/wrx camber plate will work. You will need to widen the 3 holes about 2mm each, and they are a DIRECT bolt on as long as they were orginally designed as direct bolt on...aka not a coilover mount.
November 12, 200520 yr Thats cool Will. I will have to check the local shops and see if I can locate any camber plates for any Subarus over here. Patrick
