jkrz Posted November 7, 2005 Share Posted November 7, 2005 hello everyone could anyone please help the visor lights have never worked on this vehicle unfortunately dont have an electrical print so checked all the fuses under the dash and hood also checked the bulbs themselves all are ok also for the heater buttons between the seats... are they suppose to light up when the dash lights come on or just when the heater is on joe Link to comment Share on other sites More sharing options...
Commuter Posted November 7, 2005 Share Posted November 7, 2005 hello everyonealso for the heater buttons between the seats... are they suppose to light up when the dash lights come on or just when the heater is on joe The pictogram (seat symbol) lights up when the dash lights are on. There is also an orange indicator light to show when the switch is on. It is common for the bulb to burn out for the pictogram. It is fixable if you are a bit of a DIY'er. Search for "Climate Control Backlight". There are good descriptions in there for replacing the bulb, about half way (or more) thru the thread. Commuter Link to comment Share on other sites More sharing options...
jkrz Posted November 7, 2005 Author Share Posted November 7, 2005 hello commuter thank you for the response as for the lighted pictorial of the seat are the visor lights and the light up pictorial on the same line as i said previously neither work and was wondering if there is a common problem thanks again joe Link to comment Share on other sites More sharing options...
mtsmiths Posted November 7, 2005 Share Posted November 7, 2005 As part of the deBrightonization of our 2000 Legacy I've added map and visor mirrors/lights. Power from both was pulled off the interior dome light. Link to comment Share on other sites More sharing options...
nipper Posted November 7, 2005 Share Posted November 7, 2005 hello everyonecould anyone please help the visor lights have never worked on this vehicle unfortunately dont have an electrical print so checked all the fuses under the dash and hood also checked the bulbs themselves all are ok also for the heater buttons between the seats... are they suppose to light up when the dash lights come on or just when the heater is on joe Check the obvious first, make sure the bulbs are good, The visor lights are always hot so bad switches in the visors. Check to make sure there is power at the bulb socket with the visors down, if not it is prbbly in the visor itself. Thye arent very complicated switches. The may even be servicable. The heater bulbs bettween the seats come on with the dash lights, and the power lights for them are indepent of the dash lights. The repalcements can be had from radioshack but they have to be wired in carefully. I just did it on my car, but im used to working with small circuits. nipper Link to comment Share on other sites More sharing options...
jkrz Posted November 14, 2005 Author Share Posted November 14, 2005 Hello Again! okay i have replaced the emergency flasher switch bulb which sits in the middle of the dash, also replaced the heater indicator bulbs between the seats, with the radio shack bulbs...work fine! i have disassembled the visor from the roof, rammed a set of of test probes in the connector to see if there was actually 12 volts to ground. nothing could you please help, as to where the power comes from? A. the dome light works. B.the map lights work. i thought, since it was constant power, it would come from before the switch of the map lights. the direction of the wiring seems to be going down the molding followoing the window frame. But without a print.......no clue also if it were a "switch" inside the visor.......where would it be? i checked the pivot arm on the visor itself and felt around the cloth material for some kind of protrusion....no luck you wouldn't have to destroy the cloth covering to get at it would you? thanks again for your help joe Check the obvious first, make sure the bulbs are good, The visor lights are always hot so bad switches in the visors. Check to make sure there is power at the bulb socket with the visors down, if not it is prbbly in the visor itself. Thye arent very complicated switches. The may even be servicable. The heater bulbs bettween the seats come on with the dash lights, and the power lights for them are indepent of the dash lights. The repalcements can be had from radioshack but they have to be wired in carefully. I just did it on my car, but im used to working with small circuits. nipper Link to comment Share on other sites More sharing options...
nipper Posted November 14, 2005 Share Posted November 14, 2005 so i have a 50% score here ..... sure be difficult. i played with my visor lights, and when you rotate the visor done the lights come on, but go too far and they go out. Let me poke around some more and see what i can find... nipper Link to comment Share on other sites More sharing options...
