snowstormer Posted September 30, 2003 Share Posted September 30, 2003 on the intercotire website, there are some LT225/85R14 tires available. 6.6" width and 28.7" overall diameter. the tire is a tsl/radial. do you think these will fit on an ea82 wagon with 14" pugs and a 3" byb lift? any fender trimming required? they look like they have some decent tread. anyone ever tried these? Quote Link to comment Share on other sites More sharing options...
Qman Posted September 30, 2003 Share Posted September 30, 2003 They will fit. You will probably have to do some fender trimming and well adjustments. That is the radial version of the old TSL biased ply(Super Swamper series) The radial version should be alot nicer in the morning. That tread pattern is well tested and proven. Good mud tire but not as good on the rocks. Still a good tire though. Quote Link to comment Share on other sites More sharing options...
snowstormer Posted September 30, 2003 Author Share Posted September 30, 2003 ok. thanks for the reply qman. gives me another option if the kuhmo mud terrains fall through. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted September 30, 2003 Share Posted September 30, 2003 I have the 27's on 14 inch rims, they required some fender trimming but when it came down to it, i'd rather have the swampers then the bits of fender i had to remove. besides, once you see your car with them on it you'll never want to go back to the lame 175-60 r13 Quote Link to comment Share on other sites More sharing options...
