November 10, 200520 yr The car is a ea81 hatch with no emmissions left on on it. (it's all been stripped by previous owner) I replaced the EGR valve but there is no vacuum hose for it simply isnt there. I have had the car for 3 1/2 years and the light never came on b4 but I can't seem to figure it out or find any useful info on what the problem is.. Help the thing is gonna drive me crazy.
November 10, 200520 yr could it be the connectors under the dash need to be swapped around? I know some cars have a switch built into the odometer to trigger the EGR light for mainanance reasons. I believe there are a few 2-pole connector under the dash; unplug one and plug the other in.... maybe?
November 10, 200520 yr I just went through this with my Hornet. It's triggered every 60,000(ish) miles. You can either find the connector under the dash and switch it, or pull the dash (which I was doing for a dash conversion anyways) and disconnect the bulb.
November 10, 200520 yr Author At least it is nothing to worry about. Thanks for the help now to wait till the weather clears up.
