idosubaru Posted November 18, 2005 Share Posted November 18, 2005 are regular struts interchangable on these? Quote Link to comment Share on other sites More sharing options...
Numbchux Posted November 18, 2005 Share Posted November 18, 2005 Yes...They might be different height, I'm not sure, it probably depends more on whether it's 4WD or not, but they will bolt up. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 18, 2005 Author Share Posted November 18, 2005 perfect timing, thanks! Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 18, 2005 Share Posted November 18, 2005 Yeah, they'll work. The important thing is the body type and drivetrain they came off of. I.E. 4WD wagon will all be the same whether it's DL, GL, or GL-10, same goes for 2WD sedan, etc. Even if they came off a different body type and drivetrain they will still work, but the height will be different. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 18, 2005 Author Share Posted November 18, 2005 Even if they came off a different body type and drivetrain they will still work, but the height will be different. you can cut coils to adjust the height right? Quote Link to comment Share on other sites More sharing options...
TROGDOR! Posted November 18, 2005 Share Posted November 18, 2005 Not recommended. How high or low do you want to go? Depending on your shock/spring combo, you can have up to 4 inches or more in height difference. I'm sure someone can tell you a combo that would hit the height you want. Quote Link to comment Share on other sites More sharing options...
