jelly man Posted December 1, 2005 Share Posted December 1, 2005 I'm trying to pull an engine and tranny from a couple 91 legacys. On the first legacy I pulled the tranny separate from below and it was really tight. I figured I'd pull the second set together from above and I can't see where it's hanging up and I'm afraid to use too much pressure. I've already removed all connections and the starter and radiator for extra room. It comes forward a couple inches and tilts up and is very close to fitting between the front crossmember and the firewall but I don't want to force it and maybe bust something. Has anyone done this before? Will it fit? Quote Link to comment Share on other sites More sharing options...
Gnuman Posted December 2, 2005 Share Posted December 2, 2005 I'm trying to pull an engine and tranny from a couple 91 legacys. On the first legacy I pulled the tranny separate from below and it was really tight. I figured I'd pull the second set together from above and I can't see where it's hanging up and I'm afraid to use too much pressure. I've already removed all connections and the starter and radiator for extra room. It comes forward a couple inches and tilts up and is very close to fitting between the front crossmember and the firewall but I don't want to force it and maybe bust something. Has anyone done this before? Will it fit? A manual tranny will fit. . .just. if the tranny is an Auto, take it out seperately. Quote Link to comment Share on other sites More sharing options...
