December 5, 200520 yr I need a clutch for my 1984 4wd ea81 wagon. The retail stores want over $200 for a clutch kit, which is way to much. I have been looking at ebay, but I'm a little confused on what size I need. I want to double check my facts... I need a 8 7/8 (225mm) disc and ea81 after 1983 and all ea82 clutches are the same. Is that right? I don’t want to buy the wrong one. Anyone have a good source for buying clutches at a good price? Any help would be great. Thanks
December 5, 200520 yr I got an Exedy clutch kit from ClutchCityOnline.com looks like your car would be $185.. same as my old 84. in 83 they went to a bigger clutch diameter. unless you find some crap off brand thats around what your going tospend.
December 5, 200520 yr There are 3 types of clutches. The small 2WD EA81 type... also found on 82 brats I know for sure (cause mine had one) There is the larger 83+ 4WD clutch for EA81's that you have. There is the EA82 clutch which should be the same from 85-94 I believe. Perault makes a good clutch... I have em in all my cars.
December 6, 200520 yr Yes! Listen to the man above me, he knows.... Also, try napa, they have new and re frurb. clutches for good prices.
December 6, 200520 yr Author Thanks for the good info guys. I'll let you know what clutch I end up getting.
December 8, 200520 yr Thanks for the good info guys. I'll let you know what clutch I end up getting. I have a bunch of ea 81 clutches I will never use if you want me to check sizes I have laying around .They are used and came off engines I got for airplanes .Dont know offhand what I have . Jude
