Randy_B Posted December 9, 2005 Share Posted December 9, 2005 I live in Wisconsin and its darn cold right now. All week the morning temps have been -2 to about 3 degrees going to work. On these morning the temp gauge barely comes off cold and air is luke warm coming out the vents. I have changed the thermostat. If its 15 to 30 degrees out I get more then enough heat. What can I do on these very cold days? Quote Link to comment Share on other sites More sharing options...
nipper Posted December 9, 2005 Share Posted December 9, 2005 try a higher range thermostat? i had a old civic like this, and i had to cover 1/2 the raidiator with cardboard to get heat. Are your electric cooling fans on by any chance? nipper Quote Link to comment Share on other sites More sharing options...
Tiny Clark Posted December 10, 2005 Share Posted December 10, 2005 Yea, if you do run the defroster mode, your fans will be on due to the A/C running. Use a piece of cardboard to block part of the radiator. Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted December 10, 2005 Share Posted December 10, 2005 Replace your thermostat and coolant temp sensor. Your car should operate correctly even in those temps Quote Link to comment Share on other sites More sharing options...
Setright Posted December 10, 2005 Share Posted December 10, 2005 Yep, I'm with Josh. I run in those temps and while the cabin heater can't quite produce blast furnace heat in slow city traffic, the temp needle shows normal and I stay warm. Quote Link to comment Share on other sites More sharing options...
nipper Posted December 10, 2005 Share Posted December 10, 2005 Hvae you tried running in recirculate mode. Sometimes it is so cold the temp differential across the heater core from the fresh air never gets all that hot. in recirculate mode, it will get warm in the car, Unfortunitly hit defrost and all bets are off that way. Ive had to run recir in 10 degree weather to get the car inside warm. nipper Quote Link to comment Share on other sites More sharing options...
