heat-defrost flap
82 gl wagon--
when i slide the heater to defrost, it only blows out a little bit, but more from the heat near my foot. Is there any sort of adjustment that i can make to get the flap to shut all the way? i was looking at it right now, and when i turn it to a/c the flap closes all the way, but as i slide it to heat, it opens, then only goes about halff way up when all the way on defrost...
ok, the wierdest thing happend right now... i was looking at it, and i slid the control to max AC and i had a bit of pressure on it and i heard this kinda hiss for a second, kinda like air leaking out of something... and then i moved it back to defrost and the flap was a lot closer to bieng closed, maybe only 1/4" gap instead of about 3/4" gap...
does this even make sense?
its vacum actuated. You have a vacum leak in the system. Its not weird...
nipper
nipper
Dang it....
