High Idle *FIXED* and alternate part found for CTS
My car has been idling at 1100-1600 rpms even when warm. Cleaned
and checked the IAC and it seems to be working fine. Noticed that my
coolant temp sensor didn't resemble the ones I've seen on other cars.
As I'm looking through some online parts catalogs, I run across this part
that looks just like one that's in the place my CTS should be.
http://www.rockauto.com/ref/SMP/SMPDetail2.html?AX11.jpg
They call it an "air charge temp. sensor". I guess it's functionally the
same as a coolant temp. sensor just with a different name. The fact
that it has a harness already attached is a bonus. I had already bought
the CTS so I replaced it with that. No more high idle. This other sensor
worked fine up until a few days ago. Looks like it had been on the car
for many years. I would have bought another if I didn't already have
the other CTS in hand.
So, this might be a good solution if you want to replace your CTS and
the harness at the same time because of excessive corrosion.
