October 14, 200322 yr About 5 minutes after starting up, every indivator light on my GL 10's dash lit up, but otherwise everything was normal. I decided to try fro home, and after about a mile, everyhting returned to normal. 8 miles later, the dash lit up again and the engine died. My guess is that an accumulation of salt on a connector shorted one of the computers. Thre problem is identiifying and locating the affected box. Any suggestions?
October 14, 200322 yr There's only one control computer on your car and it is under the dash. IMO, your trouble is more likely related to an alternator problem.. these cars do some weird things when the alts go bad.. and they do quite often
October 14, 200322 yr I'd also look at the two main wire connectors *under-near* the alt. for the engine connections too, just for the sake of cleanliness too. After all its just a simple lift of the tab and *POP* the wire tips are visible and checking for corrosion is rather obvious at that point for all - what 7 ? connectors? [ two big 15 and 16 pin, a couple 3 or 5 of the 2 pin type connectors] (reason I'm adding this two or three minute additional look-see is well, that which Calebz got to find on one of his old rides. then I'd take the alt. off the car and run it over to an auto parts place for testing ..... makes me wonder if its the internal/external regulator getting freaky on you.
October 14, 200322 yr Too true steve. I did get a perfectly good car because of crappy harness connections.. if by chance they are gross and corroded, cleaning them up and repacaking them with some di-electric grease can do wonders.
