Hi,
I need to remove my radio in order to get to the cigarette lighter, as mine blew. I tried to remove my radio, but can only find 2 screw behind the cupholder once removed. ANy clue would be welcomed !
Cheers
JFD
93 Legacy L Wagon
4WD
5 speed
Too much rust !
Try removing the ash-tray in the same way to find screws at the bottom. Pull the trim plate off, and there are a screw on either side of the radio, and possibly underneath it too. Don't forget to remove the antenna connector too.
Chef is right there is two screws right above the ash tray when you remove the tray. But you wont have to remove the radio to replace the lighter, or I didnt on my 97 Legacy wagon yours may be different. I replaced my center trim and lower trim this past weekend. I had trouble trying to figure out how to get lighter out of lower trim so I will tell you just in case you dont know. The part that is on the back side screws off and then you push the balance through the front. Be careful when you put the trim back in the little ears break real easy and then it will rattle on the hiway that is why I had to replace mine.
