msteel Posted February 18, 2006 Share Posted February 18, 2006 I remember reading that GLs had a cargo light, I assume in the hatch part of a wagon model. Does anyone know how easy it would be to add one to a Loyale? Was it just a second dome light in the back? Is the mounting hardware or wiring harness there on a Loyale? Quote Link to comment Share on other sites More sharing options...
Subarian Posted February 18, 2006 Share Posted February 18, 2006 It's actually rectangular and sits on the roof just in front of the door opening. I have no idea if the wiring is there, but it wouldn't be too hard to add. Quote Link to comment Share on other sites More sharing options...
fangster Posted February 18, 2006 Share Posted February 18, 2006 The wiring wasn't there in my Australian DL EA82. I just ran some wires to the centre interior light. The cargo light and centre light turn on whenever a door is open. The good news is that there is a hole for it - and the screw holes are all there. You will have to do some careful cutting in your hood lining. Mine worked out well. Incidentally can anyone tell me if the front interior spotlights (in front of the rear view mirror) are supposed to turn on when the doors open? Or are they strictly a "switch only" affair? Quote Link to comment Share on other sites More sharing options...
wb 86 Posted February 18, 2006 Share Posted February 18, 2006 ^^ I've only seen them work by using the switch Craig Quote Link to comment Share on other sites More sharing options...
Subarian Posted February 18, 2006 Share Posted February 18, 2006 Called map lights in the US. They only operate by the pushbutton switch. Quote Link to comment Share on other sites More sharing options...
RONAN Posted February 19, 2006 Share Posted February 19, 2006 I installed the map light and cargo light in my 93 loyale wagon. I bought a set from a 87 wagon off of Ebay. I felt & guesstimated where the maplight went by feeling the roof headliner for the factory cut-out. I made a small hole in the roofliner and carefully opened it up for fit. There is screw holes in the cutout that matched up to the light. For the cargo light, I popped the headliner in the back loose and found the cutout for it and made my hole in the headliner. I ran wire from the center light to feed both front and back lights. I tied in the back light so it comes on when any door or hatch is open... Quote Link to comment Share on other sites More sharing options...
