March 14, 200620 yr My daughter has 91 legacy 2wd auto. When going from park to drive there is a noticable pause before the xmsn 'catches'. Wife has a 95 legacy auto and she noticed this on the older car a couple a days ago when she took it for a short drive. The lag is an extra 2 seconds maybe. It doesn't seem to slip when running down the road. Is it soon to fail? Have heard mention of a product called Trans X. Any word on this stuff? Or should we start shopping for a used xmsn? rick w mi
March 15, 200620 yr Have you recently checked the transmission fluid level? Or changed the fluid? I would start there. If you haven't changed the fluid in a while, do that.
March 16, 200620 yr Author Fluid was little low. Topped up and no difference. Will have her change fluid. Should be cheap shot. Again, is there any word on this TRANS X stuff. tnx Rick w mi
March 19, 200620 yr I haven't heard anything about the trans x stuff. However if your trans is really on its way out.....no amount of additives will help.
March 19, 200620 yr Flush the tranny. A lag is a sticking valve in the valve body. If everyimg else shifts ok, you may have to live with it. Other choice is to go to a shop and have them put a pressure gauge on it and see what pressures the tranny is operating at. How does the car shift otherwise? nipper
March 21, 200620 yr Author From what I can tell, the tranny shifts just fine. What pressure should the xmsn run at? I s'pose the guys with the gauges should know. If all she has to deal with is the lag to engage I see no big issues. tnx rick w. mi.
March 21, 200620 yr It's not that easy as me telling you "x" pressure, as there are various pressures for various shift points. I dont have the tranny book around, so i am not sure, but do record the numbers and share them. nipper
