90 legacy xmsn question. Trans x any good?
My daughter has 91 legacy 2wd auto.
When going from park to drive there is a noticable pause before the xmsn 'catches'. Wife has a 95 legacy auto and she noticed this on the older car a couple a days ago when she took it for a short drive. The lag is an extra 2 seconds maybe. It doesn't seem to slip when running down the road.
Is it soon to fail?
Have heard mention of a product called Trans X.
Any word on this stuff? Or should we start shopping for a used xmsn?
rick
w mi
Fluid was little low. Topped up and no difference.
Will have her change fluid. Should be cheap shot.
Again, is there any word on this TRANS X stuff.
tnx
Rick
w mi
Flush the tranny. A lag is a sticking valve in the valve body. If everyimg else shifts ok, you may have to live with it. Other choice is to go to a shop and have them put a pressure gauge on it and see what pressures the tranny is operating at.
How does the car shift otherwise?
nipper
From what I can tell, the tranny shifts just fine.
What pressure should the xmsn run at?
I s'pose the guys with the gauges should know.
If all she has to deal with is the lag to engage I see no big issues.
tnx
rick
w. mi.
It's not that easy as me telling you "x" pressure, as there are various pressures for various shift points. I dont have the tranny book around, so i am not sure, but do record the numbers and share them.
nipper
