March 16, 200620 yr Should there be a shaft sticking out of the back of the torque converter that fits into the crankshaft? Torque Converter http://www.ultimatesubaru.org/photos/showphoto.php?photo=10295&cat=500&ppuser=14202 Crankshaft http://www.ultimatesubaru.org/photos/showphoto.php?photo=10296&cat=500&ppuser=14202
March 16, 200620 yr There should be a shaft that sticks out from the torque converter that less than an inch long. It's there to keep the torque converter aligned with the crank.
March 16, 200620 yr Author There should be a shaft that sticks out from the torque converter that less than an inch long. It's there to keep the torque converter aligned with the crank. That means the shaft on my torque convertor is broken off in the crankshaft. I think thats why when I put the manual tranny in, it seemed like the clutch would not disengage. Got any ideas on how to get the broken piece out of the crankshaft?
March 16, 200620 yr Soak it with penetrating oil then hit it sideways with a sharp chisel, being careful not to mark the crank.
March 16, 200620 yr Author Soak it with penetrating oil then hit it sideways with a sharp chisel, being careful not to mark the crank. If that doesn't work could I use a drill bit a little smaller than the shaft to drill it out?
March 17, 200620 yr Author I got the broken piece out! Is there a bearing that should go in there like in the flywheel or not?
March 17, 200620 yr Yeah, the pilot bearing. It presses into the 1" hole in the flywheel and centers the tranny shaft. It should come with a decent clutch kit.
March 17, 200620 yr Author Yeah, the pilot bearing. It presses into the 1" hole in the flywheel and centers the tranny shaft. It should come with a decent clutch kit. I mean is there a bearing that goes in the little hole in the crankshaft? I don't think there is just wanted to make sure before I put the engine back in.
March 17, 200620 yr Author no bearing goes in the crankshaft side. nice hit on getting it out. It took me and a friend like 2 hours to get that peice out. Thats another peice i'm keeping. Thanks for all the info. Just go to get the engine back in.
