jakl Posted March 22, 2006 Share Posted March 22, 2006 Hi Folks, My '95 Legacy L started getting loud. Noisy exhaust system revealed rear cat converter crack/hole where flange bolts to mid-pipe. Part on order - will attempt installation. Seems easy enough, unbolt/bolt in new part. Can I use the same O2 sensor? Any suggestions or pitfalls I should be aware of? Thanks in advance, jakl Quote Link to comment Share on other sites More sharing options...
nipper Posted March 22, 2006 Share Posted March 22, 2006 Hi Folks, My '95 Legacy L started getting loud. Noisy exhaust system revealed rear cat converter crack/hole where flange bolts to mid-pipe.Part on order - will attempt installation. Seems easy enough, unbolt/bolt in new part. Can I use the same O2 sensor? Any suggestions or pitfalls I should be aware of? Thanks in advance, jakl i would replace the O2 sensor if its the original one. It is a fairly straight forward job. Soak the bolts in penetrating oil as much as possible and let it soak. It will make life easier. nipper Quote Link to comment Share on other sites More sharing options...
