March 22, 200620 yr Where are the relays for the turn signals? Ever since I got the GL, the turn signals have not worked. The hazards work, but not the turns.
March 22, 200620 yr What model? EA81 is above the release lever for the hood - driver side under the dash EA82.... similar, but not sure on exact location. Take off the kick panel and you'll find it. It's a pretty obvious looking black relay-ish thing - little bigger than a similarly packaged relay. Edit - it's not a relay - it's a "flasher" module. Looks a lot like a relay tho. Blinkers have no relay to themselves. GD
March 22, 200620 yr Author What model? EA81 is above the release lever for the hood - driver side under the dash EA82.... similar, but not sure on exact location. Take off the kick panel and you'll find it. It's a pretty obvious looking black relay-ish thing - little bigger than a similarly packaged relay. Edit - it's not a relay - it's a "flasher" module. Looks a lot like a relay tho. Blinkers have no relay to themselves. GD EA82. Actually, it is refered to as a relay considering the insides have a piece of spring metal wrapped in a resistance wire which heats up the spring metal and forces it to touch a contact. It's technical name is a thermal flasher. I've never heard it called a flasher module. I know a strobe light internals are called flasher modules. A module refers to self contained unit that has circuitry in it, like an engine ecu.
