Maybe I'll have better luck with mechanics then back surgons:)
After the car sitting for several months, it seems the valve stem seals have given up the fight. The car puts out a big blue cloud when first started in the morning. The rest of the day it seems fine.
The engine has 182k on it (runs like a trooper), and I hate oil burning. The car will most likely be due for a heavy maint in the summer (seals water pump timing belt). I know from past exp that the timing belt and etc is 600 $ or so. I have no idea how much it is to replace the valve guide seals. i love the car, and the car is solid and well maintained.
I am thinking of replacing the engine with a rebuilt 2.5 L from CCR (sorry guys but a rebuild gets around the HG issues).
Now i live in Oceanside, Long Island, NY.
I am hesitant from using a general engine rebuilder.
Questions:
1-Has anyone had a sooby engine rebuilt by anyone besides Subaru or CCR (national chain prefered)
2-Can anyone recomend a shop in my area that has worked with CCR (if i go that route)
3-Do you think im nuts? (might be the pain meds)
thanks
nipper
Dont give up on the back, when I had the disc done in my neck it took a while to heal. I am sure you know this but just in case you dont you can have the valve stem seals fixed for very little money. I think you just remove the valve cover and fill the cyclinder with air. I am not sure on the details but I am sure someone here is. I had some done this way on a 305 chev. engine years back.
Questions:
thanks
nipper
Thanks, since it was two surgeries(first one failed) almost back to back (28 days), may take the better part of the year to heal. Then i need to find a new job :(.
I know on V and inline engine you have plenty of room to remove the valve springs and rocker arms. The 2.5L is tight in there and i am envisioning them pulling the heads to do this, which means HG's and that 1500.00 price, which is 1/2 the cost of an engine
nipper
Another thing might be that you are not running it enough. I say this because my 65 GTO started the other day with a cloud like a steam engine. It sat all winter and the oil seems to have gone by the seals I think. I have started it a couple of time since and it is not smoking again, but if it sits it will.
i use it once a day now, to get the newspaper and get the hell out of the house (cabin feever). Everymorning a big blue cloud, after that it seems fine.
nipper
