Rhubey Posted March 30, 2006 Share Posted March 30, 2006 OK, here are the clues...:-\ 1. 91 Legacy 5spd 2. EJ22 non turbo 3. located @ the front top center edge, below the alternator, in front of the " EJ22 " stamp on the block. Have a guess yet??? Here are more clues... 4. It is approx 3" long cylinder mounted vertically. 5. It has an approx 20mm hex molded at the top for removal. 6. It is attatched w/a single conductor, w/a spade type connector @ the top. 7. It sometimes "burps" oil up through the center ( between the dialectric and conductor) and leaves your engine stinky when it warms-up. Quote Link to comment Share on other sites More sharing options...
e4620 Posted March 30, 2006 Share Posted March 30, 2006 Oil pressure sensor? Quote Link to comment Share on other sites More sharing options...
frag Posted March 30, 2006 Share Posted March 30, 2006 It is the electrical oil pressure sender. On my car I've connected a T fitting to the port with the sender on one end and a copper tube on the other leading to a mechanical oil pressure gauge. What is there to win??? Quote Link to comment Share on other sites More sharing options...
