April 6, 200620 yr Its time to replace the struts on my 86 brat but if i am going to do it i want the best i can afford Ideally some longer struts would be best so when I lift it I wont have to lower the strut mounts. If that is not possible I would like to at least gain a little suspension travel. I have heard that you can use the struts from a 73 super beetle and gain some travel but I need mare info before i put the effort forth to find these. If you have used these struts or if you know of a better mod PLEASE chime in with your thought opinions or musings.
April 10, 200619 yr I want to do the same thing as you. Here's what I found: (courtesy of RenaissanceMan) http://ultimatesubaru.org/forum/showthread.php?t=48275
April 10, 200619 yr Looks very nice!I may have to do something like that with my hatch.Anyone else do something similar?
