April 20, 200620 yr Yeah, me too. I'm hoping this is the last of the BS I have to deal with on this car. These 93's are supposed to be pretty reliable, from what I've seen...but so far, in three weeks time, here's a list of what I've replaced: Timing Belt. All other serpentine belts. Water Pump Brakes Thermostat (twice) Battery Alternator I've got to believe that it's going to run well for a while now, right??? heh. In all seriousness, I like this car alot...hopefully it treats me as well as I've treated it. Actually that is nothing out of line for buying a used car. All those items are maint or wear tiems. Assuming you resealed the engine with the timing belts (you did do that i hope) you shouldnt have a problem till the next timing belt change. nipper
April 20, 200620 yr Author I didn't replace the timing belt...that's a bit out of my league. The service center did that for me. Otherwise, you're right - but all those things at once do not make for a happy pocketbook. Actually that is nothing out of line for buying a used car. All those items are maint or wear tiems. Assuming you resealed the engine with the timing belts (you did do that i hope) you shouldnt have a problem till the next timing belt change. nipper
