April 19, 200619 yr Is the rear wiper on the 05 outback a dealer part? The way it attaches seems like it may be. Also, it doesn't look like you can just change the rubber. Thanks.
April 19, 200619 yr hello it's simpl0er to just buy a new blade assy - rather than a refill the blades are nearly the same cost anyway! and yes, this is a dealer part for the rear wiper assy for your 05..... view pricing, or to order : 1) you will need to use our OEM catalog to access https://www.subarugenuineparts.com/oe_parts_cat.html 2) look up by part number - - 86542AG09A COMPLETE, new assembly with wiper refill preassembled hope this helps Jamie Thomas Jamie at chaplins.com *************************** http://www.subiegal.com
April 19, 200619 yr its a factory installed feature (in north america), since there isn't a single one that doesnt have on in 2005 that i know of. What makes it look like a dealer installed option to you? The balde can be replaced, i dont know if the arm is a dealer only part. i've always gotten blades a retailer. nipper
