April 20, 200619 yr Car is: 1981 4WD GL Wagon, 1.8 - 4spd yadda-yadda Problem: Turn signals flash normal for a SHORT while (maybe 15 seconds) then start blinking faster and faster..... THEN... they just stay solid (on). Anyone got any ideas about whats going on? Oh yea, solutions too, I'd like one of those . Have a co worker comming to buy the car and need this sorted out before hand. - Erik - Tacoma, WA -
April 20, 200619 yr I would look to the flasher unit as the culprit here. Can't say as I've ever ran into a problem as you describe though, so not sure. Turn signal issues usually can be troubleshot by how they flash, or don't flash. Rapid flashing of the dash indicator, usually indicates a front bulb is out. Dash indicator "on", but not flashing points to a rear bulb out, or the flasher unit itself if the rear bulb is lit. The system will, (umm should), work normally if the dash indicator burns out. With that said, corrosion in the bulb sockets should aslo be looked for, especially if the bulbs are known to be good. Bad connection on either the front or rear of the system will act just like a blown bulb would.
April 20, 200619 yr Author Totally forgot to mention it does this both right and left - in an identical manner... sorry - Erik - Tacoma, WA -
April 20, 200619 yr Would still look at flasher as culprit, even more now as it's both sides giving trouble. Could be a wiring issue or switch issue, but bulbs and flasher unit be the easiest things to check first.
April 20, 200619 yr I vote with tom - I dont see how the bulbs could cause it - my second suspect would be the turn signal switch itself check grounds too
April 20, 200619 yr hey erik it is more than likely the flasher heats up after a few clicks and then get stuck in the on position. bty...call me...i lost your number when i moved my desk.(suspect the wife threw it away) Dave
April 20, 200619 yr Author Problem solved. It was the flasher in a roundabout way. I replaced the flasher unit with a used one a few years ago but I think my friend who I sold it to replaced it with an incorrect spec. flasher. Swapped hazard and flasher cylinders to test and the symptoms carried over. Also put in a Brand-spankin-new flasher I had sitting in the garage to the same effect... Took the 'good' one to Baxter and picked up an identical one, pluged em in and wa'la - turns out thats what it was. Didn't realize there were all too many different variations (and how/why he and I had some strange off-breed that we put in) at any rate - next step: rewiring fuel pump! - Erik - Tacoma, WA -
