April 20, 200619 yr Hi All Would anyone know if the bolt pattern on the EA81/82 flywheel is the same as the bolt pattern on the EJ series engine flywheel? Many thanks in advance, James
April 21, 200619 yr EA81 and EA82 flywheels will interchange between each other, but they use an odd-space bolt pattern so they only go on in ONE way (because the timing marks are on it) - the EJ engines use an even-spaced bolt pattern - EA flywheels can be adapted tho to work on EJ engines - ask someone who has done the conversion, and they can tell you how
April 21, 200619 yr no need to ask, just type in the words "ej swap" and you've got plenty of reading for the day. ~Josh~
