Rob Kuhlman Posted April 29, 2006 Share Posted April 29, 2006 My son from whom I purchased this '95 Legacy wagon 6 weeks ago reminded me a week ago, "By the way, the high beams stopped working last fall." Here's what they do: I can flash them by pulling back on the switch lever, but pushing forward on the lever doesn't illuminate them. In browsing through the Haynes manual, I sensed the '95 Legacy has a relay for each side but not a special relay to power the high beams. Is that correct? And, if so, am I looking at a defective switch lever assembly? It seems unlikely to me that both sides' relays could have gone belly up at the same time. And...the relays light the high beams when I pull on the lever to flash them. That's why I'm thinking switch. Rob Kuhlman Quote Link to comment Share on other sites More sharing options...
nipper Posted April 29, 2006 Share Posted April 29, 2006 My son from whom I purchased this '95 Legacy wagon 6 weeks ago reminded me a week ago, "By the way, the high beams stopped working last fall." Here's what they do: I can flash them by pulling back on the switch lever, but pushing forward on the lever doesn't illuminate them. In browsing through the Haynes manual, I sensed the '95 Legacy has a relay for each side but not a special relay to power the high beams. Is that correct? And, if so, am I looking at a defective switch lever assembly? It seems unlikely to me that both sides' relays could have gone belly up at the same time. And...the relays light the high beams when I pull on the lever to flash them. That's why I'm thinking switch. Rob Kuhlman i tend to agree. The switch has a seperate leg for constant hi, as opposed to flash. Could be that contact is worn out since everything else works. You can take a meter to the switch and confirm it. nipper Quote Link to comment Share on other sites More sharing options...
Subie Gal Posted April 29, 2006 Share Posted April 29, 2006 sure sounds like the main lever/combination switch assy. be sure to check all relay's and fuses but i think i'd lean towards a burned out headlight lever/stalk Jamie Quote Link to comment Share on other sites More sharing options...
