EA82T customed
I am curious about EA82T and thier mods. They aren't popular here due to the extreme elements(shamefully).In fact the non-turbo old carbuerated would be more popular than the SPFI if more available. I have read about enthusiastic projects elsewhere and am curious what is the most an EA82T has achieved. I did find an old rx (87ish 4 headlights) rusting away, (unless it just looks like one with a turbo) and may dive in to the challenge if owner lets go.I have fantastic luck with the higher compression and tinkering, no turbo or EGR at all.
I think the most anyone here on this board has achieved with an EA82T, has been WJM. He has gotten roughly 230 crank hp out of one in his '87 RX coupe. I am currently working on getting more out of it, but I have tuning issues and some other things like that before I can take it to the awd dyno down in Colorado to see what I'm putting out.
Thats about the same hp as one we recently dynoed 223hp....apparently the weak link in the turbos are the pistons at this level of tune....
heads/headgaskets are the weak link.
Rear main and rings seem to be my weak links. Some carbon steel inserts and a bit of overtorquing seems to have solved the HG problem for me.
Read, and dream...
Item 85 Ex-rally Leone RX
Condition Engine = New
Driveline = New
Interior = Good
Body = Average. Rust above windscreen, rear quarter glass & wheel arch.
Location Benowa Waters, Gold Coast
Price Offers over $5000.
Contact me PM, simon.neden@austar.com.au or 0414502886
Due to a change in lifestyle, I gotta recover some of my costs.
Have spent over $12,000 in the last year on it with the intention of finishing the project. No expense was spared with the build, all work done by professionals. Only thing I didnt get done was the bodywork. Have all the genuine RX side strips, front rubber skirt & boot spoiler & grille (not fitted)
Current engine contains all the good bits - custom forged pistons, chrome rings, balanced crank & rods, large duration cams, o-ringed heads good for 30psi+ boost.
Complete new fuel system (Haltech F10x, Bosch 550hp external pump, Malpassi hi-pressure regulator, 3 bar MAP sensor, all new wiring)
New driveline (fresh gearbox, clutch & flywheel new rear subframe, suspension arms, drive-shafts, brake rotors and wheel bearings)
These are the componants that have only just been replaced. See below for complete list of mods. Comes with 2 sets of wheels (15" Superlites & 13" Enkei rally) both have new sets of tires. Will supply personalised plates ORX.18 (QLD) and stereo at buyers discression.
Specs:
Engine:
- EA82T
- Custom forged 92.5mm pistons (SPS Pistons)
- Chrome rings
- O-ringed heads/block
- Modified cams
- Balanced crank & rods
- New lifters
- Larger valves/springs
- Lots of headwork
- Custom radiator & new water pump
- Custom turbo manifold
- VF-10 turbo (18psi)
- 3" Core custom bar & plate intercooler approx 700mm x 350mm
- 2.5" Chromed intercooler plumbing
- Turbonetics adaptors
- 3" Mandrel bent exhaust & dump pipe, single muffler to 3" tip
- 4" Inlet K&N filtercharger
- Stainless steel oil catch can w/ K&N filter & brass fittings
- Chromed custom strut brace
- Seam welded front end
Fuel System
- Haltech F10x progammable ECU
- 3 Bar map sensor
- Malpassi adjustable fuel pressure regulator
- Bosch Motorsport 044 550hp external fuel pump
- 330cc injectors (need bigger for higher boost - 20+psi)
- 10mm Top Gun leads
- NGK Iridium plugs
- GFB Boost controller
Driveline
- Custom clutch (uprated diaphragm)
- 1 tonne pressure plate
- Lightened flywheel
- Adjustable coil-overs (fr)
- Enkei minilites 13x5s incl spare
- Performace super-lites 15x7 incl spare
- Bendix Metal King pads
Inside
- Momo Corse steering wheel & boss kit
- Autometer Pro-Comp Ultra-Lite 30psi Boost, Water Temp & Oil Press guages
- HKS elec turbo timer
- Boot mounted battery
- Pioneer DEH-P723 CD player
- Kicker KX3504 amplifier
- Pioneer 15" Sub in sealed enclosure
- Focal 4" Splits
I have same color sedan :)
That's is a lot of power. Did you brace anything in the trunk on the sedan? I found something weird back there, not a weakness but a bender/twister below rear window.... After that hunch I lost rear bearings simultaneously in a way that took the 2 rear wheels steering to the right. I search for this "torque on the body" stuff since my GM v8 and a t-top coupe (damn near catastrophe!). 4wd must be a big help to disperse power.Very Nice setup. :burnout:
would this possibly be a F-body car? I know how you feel on that one...
