pearlm30 Posted May 10, 2006 Share Posted May 10, 2006 Its for MY 93 Impreza AWD auto. I would like to get an upgrade cheaply from junkyard. I found a 93 legacy turbo and 95 legacy. Are the brakes caliper direct bolt on? Any advice??? Thanks for the help Quote Link to comment Share on other sites More sharing options...
jamal Posted May 10, 2006 Share Posted May 10, 2006 the turbo brakes are 2-piston fronts with bigger rotors. The rears are vented. Pull everything off if it's there. It bolts right on. Also you should probably grab the rear sway bar. the 95 stuff won't really be an upgrade. Quote Link to comment Share on other sites More sharing options...
pearlm30 Posted May 10, 2006 Author Share Posted May 10, 2006 Do I need bigger wheels if I put the turbo brakes on? MY 93 Impreza came with 14 inch and the turbo were 15 inch. Thanks the turbo brakes are 2-piston fronts with bigger rotors. The rears are vented. Pull everything off if it's there. It bolts right on. Also you should probably grab the rear sway bar. the 95 stuff won't really be an upgrade. Quote Link to comment Share on other sites More sharing options...
jamal Posted May 10, 2006 Share Posted May 10, 2006 yeah 15" minimum up front. Quote Link to comment Share on other sites More sharing options...
