fnlyfnd Posted May 11, 2006 Share Posted May 11, 2006 Although my leaks are minor i want to fix them...1996 2.2L 5spd 1.) The plastic cover on the front of the engine - the bottom is leaking. what is this?? 2.) Valve cover maybe - will post pics tom. if not raining. Anybody have a pdf or anything showing the engine broken down with numbers listing parts?? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 11, 2006 Share Posted May 11, 2006 do you mean the timing belt cover? You probabaly have the usual culprits to suspect, oil pump, crank seal or cam seals. nipper Quote Link to comment Share on other sites More sharing options...
sid_vicious Posted May 11, 2006 Share Posted May 11, 2006 Although my leaks are minor i want to fix them...1996 2.2L 5spd1.) The plastic cover on the front of the engine - the bottom is leaking. what is this?? 2.) Valve cover maybe - will post pics tom. if not raining. Anybody have a pdf or anything showing the engine broken down with numbers listing parts?? The plastic cover at the front of the engine is the timing belt cover. It might be covering a more significant leak than you think because the cover's gasket could be holding in some of the oil, even though it has already leaked out of the engine. The leak is likely to be coming from one of the cam seals or the oil pump, all of which are covered by the timing belt cover. Remove the cover, and it should be clear where the leak is coming from. A search should get you plenty of threads on the subject. Quote Link to comment Share on other sites More sharing options...
fnlyfnd Posted May 11, 2006 Author Share Posted May 11, 2006 thanks. I had no idea that all that was under the cover. I tried searching for front main seal (which i thought it was), but obviously it returned no results. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 11, 2006 Share Posted May 11, 2006 What is under the front cover; Timing Belt cam seals main (crank) seal Oil Pump Water Pump This is the time to replace all those goodies and the timing belt tensioner too. DO all this you will be good for 100,000 miles nipper Quote Link to comment Share on other sites More sharing options...
fnlyfnd Posted May 11, 2006 Author Share Posted May 11, 2006 couple more weeks I will have the moolay...I hope Quote Link to comment Share on other sites More sharing options...
