xt troubles still troublin me
hi i posted a thread a couple days back about my 89 xt.
the timing belt is on propley and refitted
pistons have full compression.
fuel pump working fine
injectors working fine
new distributer
new battery
plenty of spark
auto electrician cant find anything rong with electricals
mechanic cant find wats rong with it
I HAVE NO IDEA WATS RONG WITH IT:mad:
if anyone has any sugestions please post them
the car has every single thing for a good working car but it just wont start
is the distributor lined up properly? this can be easy to get wrong.
do you have another distributor to swap in and try?
what is this? a turbo, non-turbo?
has the engine ever been pulled or had major work done to it?
no check engine light?
did you use any parts that might not be compatible...like earlier year ECU?
...did you use any parts that might not be compatible...like earlier year ECU?
Maybe this... Or Maybe a burnt Distribuitor Module... I Suggest to Check them, but if "Plenty Spark" you got, Have you Checked the Fuel Pump and Hoses / Connections? :confused:
