June 2, 200619 yr 97 impreza OBS with ABS. will 1993 Legacy 2 pot calipers fit? would the 2 pot calipers be better than my stock 1 pot? and why are 2 better?
June 2, 200619 yr and why are 2 better? Spreads the pressure out across the pad so you get greater surface area that receives the pressure. Basically there is a greater surface are for those two slightly smaller pistons than there is for just the one slightly larger piston. Keith
June 2, 200619 yr Author there is a greater surface are for those two slightly smaller pistons than there is for just the one slightly larger piston. cool thanks, just like # of valves per cylinder!
June 3, 200619 yr Eh? The big difference is that one-pot uses a 260mm disc and the two pots work on 277mm.
June 3, 200619 yr You'll have to see if your hubs have the same caliper mounting tabs. There is a difference between my 96 base Impreza and 98RS. Jay
