will a non turbo tranny fit turbo engine??
i have a question, i have a 5 spd D/R working with EA82 MPFI, and will this tranny fit a EA 82 Turbo??
thanks, take care
Yes it will. You will also need a 3.9 diff to go with it.
Also may need to change axles or change something on them. Turbo and non Turobs have different spline counts on the trannys.
You will need:
The tranny and all of its mounting equipment
The shifter assembly and the console
Non turbo half shafts.
3.9 rear diff
You may want to replace the clutch while you are in there.
It is a days work, but worth the effort.
Have fun
Mike
I forgot, if you are changing from an auto tranny, you will need the pedal assembly, clutch cable and the driveshaft.
i forgot to say that in this Turbo soobe ther is a 5 spd D/R, i know that turbo axels are stronger and i know that people are putting those in regular soobs ;)
but i have a 3.700 rear diff whit mine tranny, the car was put a part few years ago, but i only drive off road with it. you think that somone made a mess??
tahanks for help, take care
konrad
Also, if you are changing from a 3AT, you won't need to change the axles ;)
konrad
It isn't so much that the turbo axles are stronger than the NA (though they are... a little), its that the spline count on the tranny side of the axles are different.
Turbo manual and 4EAT - 25 spline
Everything else - 23 spline.
