I need a quick clarification.
I need to know if a 3at pushbutton 4wd out of an '85 EA82 car is a direct swap for the 3at pushbutton 4wd out of a '84 EA81 car. I'm 90% sure they are the same animal.
How different? The donor car is locked up, not sure if I will be able to get the TC off of the flexplate.
I think what Rob means is the TC are different for the cars. Your TC on the tranny you have now should slide right onto the input splines and have no issues. I believe its all internal on the TC.
The Tail housing and rear output shaft on the EA81 version are longer then the ones on a EA82, similar to how a D/R 4 speed is longer then a D/R 5 speed. I have had a couple of dozen 3ATs apart and those parts can be swapped fairly easly; you will need to make sure that you keep transfer gear set matched up.
I'm going to GravelRx's house on Sunday to retrieve the trans in question. It sounds like it will work, with just a bit of effort.
